Indie-Snap Flex-Track Dolly Review
Before I continue, I would just like to give a shout-out to Todd Poirier from Indiesnap! This guy really cares about his customer. When there was a few shipping issues with UPS, Todd was right on top of it and kept in touch with me constantly via email. He always responded quickly to my questions and is genuinely committed to make sure I’m satisfied with the product. When this guy says “Satisfaction Guaranteed,” he really means it. I would buy again from him any time.
What’s Included
The Flex-track consists of a tripod dolly that has been modified with four wheels on each leg (12 totals) and 30 ft (two 15 ft runs) of rubber tracks. The tripod dolly looks very sleek with black wheels and black finished; this thing does not look like a DIY project at all, which is a big plus. The rubber track is about an inch in diameter, is very thick and firm so the wheels will not depress it when going over. It’s very flexible and can easily be twisted into any shape you want, but tough enough so that it’ll hold that shape. One problem I’ve found though is that after coiling the track for storage, the ends tend to bends, which means a problem for when you want to set up a straight track pattern. Todd recommends taping the end of the track down when doing straight run. U channels are included that go under the track to keep it perfectly straight, but I’ve found that the U channels are rather shallow, and it’s easy for the rubber track to pop out, especially if the ends are bend. Some tape on set would definitely help this situation.
Operation
I initially had a little trouble putting the tripod on to the tripod dolly, as you have to manually align the 3 clamps that hold the tripod leg in place. It’s a rather tricky process at first and takes a few minutes but after I got the tripod on I was able to get it on and off the dolly fairly quickly. Laying the tracks down may also take you a few minutes as you have to roll the dolly over it a few times and make minor adjustments to the track alignment so that the wheels will not pop off the track. As I got better at it, I was able to do this faster as well.
When I got everything ready and start shooting indoor test footages, my first few thoughts were “Whoa!” Within 10 minutes I was able to get some good (not quite perfect, but definitely usable footage). With any tool, it takes practice to get good results, and the Flex-Track is no different. The challenge with this type of one-operator dolly is that you have to both push the dolly and control the camera at the same time. A lot of the stumbles at first came from the dolly bumping into my foot as I move and jerky panning. With the A1, I found that the best way is to stand inside the two tracks and adjust the LCD so that I can see from the side of the camera. The wheels themselves roll smooth as silk over the rubber track with no noticeable bumps (assuming track is correctly configured), and it’s just a pleasure to use.
So the Flex-Track performs superbly indoor with a fairly smooth surface (my apartment’s carpet), but how does it fare outside? As it turns out, almost as good. I did testing on a variety of surfaces, from smooth stones to concrete tiles, and the wheels continue to move smoothly over the track (see sample footage). Surfaces that are rocky or really bumpy will not accommodate the Flex-Track, and neither will grassy area. But I think for most outdoor use it’s good, and if you really need it in a bumpy place, the included U-channels have holes pre-drilled into them so you can screw it on to a wooden board as a shim.
The main advantage of the system, of course, is that it’s incredibly portable. Everything (tracks, dolly etc.) fit into a nice carrying case (included) and you can carry it around easily. Still not a light setup, but certainly much easier to lug around than long sets of tracks and dolly platforms. And it’ll accommodate smaller spaces that a larger dolly might not be able to fit. And with 15 ft of track to start with, you’re good to go for most situations. I would like to see Todd comes up with a system to extend the length of the track though should we need it. Right now there’s a 15 ft. and 25 ft. options available but I would like to be able to purchase new track and attach them to my current ones without sacrificing the flexibility of the system.
Overall Impression
I’ve never realized how much a dolly can do in term of opening up new creative possibilities. With the Flex-Track I was able to get some very dynamic shots that greatly enhanced the production values of the film. The system certainly has some flaws, mainly difficult to set up straight runs and micromanagement of track alignments, but at this price, it’s simply a great value for any filmmakers who are looking to stage more unique shots. In fact, after seeing some of the shots that the Flex-Track can do, I’m going to incorporate these moves into my film and start planning more organic blockings than I thought was possible.
Another important factor for me is the level of customer service. We’re all afraid of dropping money on a bum product that doesn’t do what we want and getting stuck with it. Todd stands firmly behind all of his products and he always provides excellent service and support if I need it. Like you, I don’t have a lot of money to spend on equipment and I’m always looking for the best bang for the buck. I believed I’ve found one in the Flex-Track system. I don’t work for Indiesnap! nor am I being paid to write this review. I simply want to share my experience with my fellow filmmakers to hopefully help you guys make an informed decision.
Pictures
Dolly Setup
Flex Track
Wheels
Tripod Dolly
Clamp
U-Channel
Bag
Footage
DISCLAIMER: I shot these footages after spending less than a day with the Flex-Track. Any mistakes that are evident are my poor dollying skill (is that even a word?) and not the fault of the dolly itself. With practice I believe the system is capable of producing much better footages than this.
http://youngsterproduction.com/videos/Dolly%20Test.mov
UPDATE: After using this dolly on my short film The Girl from Yesterday, I'm absolutely confident that it can produce amazing results with some practice. The trailer for the film has quite a few dolly shots using the Flex Track, you can either see it on Youtube or check out a 720p version in this thread
http://www.dvxuser.com/V6/showthread.php?t=114036
