Exit
Like an ever-increasing number of you, I'm using a 35mm adapter with my DVX and a rail system. The next step is buying a follow focus. With the exception of a few ingenious DIY inventions, the only affordable (less than $500) follow focus solution I can find is the IndieFocus ($300). I'm a little concerned with the friction design, however.
My reason for using rails with the adapter is to take stress of the threads connecting the adapter to the DVX but I'm afraid that the Indie Focus might add horizontal stress on the threads the way gravity would if I weren't using a rail system.
I'm worried that there will either be too much tension on the lens or not enough tension on the adapter, causing slippage and inconsistent control. Has anyone used this follow focus with a 35mm adapter? Do you have any other follow focus suggestions?
