Importing HVX200a to Premiere Pro 2.0
Ruka
Hi, I recently bought a HVX200a, and I have been having problems importing video from the P2 card that use the MXF coding to Premiere pro 2.0 . When I use the tape deck it works normal. However when I try to import from the P2 card, I always get the same message, File format not supported. Can I correct this with a plugin or do I need to have the latest version of premiere?
I have already tried copying the whole Contents folder + the Last clip file to my pc but the same error keeps on happening.
Thanks for the attention.
Yes you need either a plugin (such as Raylight which is very good) or a newer version of Premiere in order to import the mxf files.
