Importing clips from DVD and other formats
We made an interview (DVCPro50) with the Panasonic HVX-200 and had to also add clips from a DVD, the internet... When I bring the DVD clips (mpeg) into Premiere CS3 I have to stretch the frame in the Program monitor so the two clips will be the same size. Everything looks the same size in the Program monitor, but when I export the movie I get a black stripe on both the top and bottom of the frame in the only. Can someone help me understand and fix the problem?
________________________________________________________
Project settings
Editing Mode:DV NTSC
Frame size: (720X480) 16:9
Export settings (video)
Format: Windows Media
Preset: NTSC Source to Download 256 KB
Weidth & Height: 320X240
Frame Rate: 29.97
Pixel Aspect Ratio: Square Pixel (1.0)
Decoder Complexity: Auto
___________________________________________________________
The PAR for the interview is 0.9 (720X480)
and the PAR for the clips added to the timeline is the same but there is a black frame all around. (the dimensions of the image is 540X428 (PAR???).
I want to make the video image fit the frame without the black frame around. I use the scale in the video effects panel, but when I export the video I get a black stripe on the top and bottom in the interview section only. I did try interpret footage with no success.
All help is appreciated, Thanks
Thought of comming back and tell how I resolved the problem:
Started a new project with 4:3 format instead of 16:9. Imported my 16:9 interviews in the new project along with the DVD clips. Solution was easier to find than I thought and the quality of DVD clips is better because I did not have to stretch them to fit the 16:9 size.
