IMPORTING @ 25 frames
mynamesbuck
Hi
What seeting would i use to import at 25 prgressive frames per second. (i have a pal model).
Also could you explain a bit about the using pull downs etc. What does that mean.
Thanks to anyone who can help. Ive looked over the site and love the forum.
Bye :)
Re: IMPORTING @ 25 frames
For a PAL project you just select the preset DV PAL 48KHz, if you shoot 4:3 or DV PAL 48KHz Anamorphic if you shoot with an anamorphic adapter or Squeeze (if you own the DVX100AE).
Also, don't forget to set the Field Dominance to None in your Sequece settings.
The Pull Down thing is for the DVX NTSC. So, you don't have to worry about that.
Hope that helps
All the best
Fidel.
