Import problems with Davinci Resolve!!
DDirector
I edited my stuff in Premiere CC.
A majority of my stuff is slow motion or has ramping. Some is regular speed.
Normally when shooting slow motion on the C300, it is already in slow motion and shouldn't be a problem. But sometimes I have to slow down the speed manually.
In this case, that's the majority of the clips.
I'm guessing this is the problem I'm having.
I'm getting the correct clips, and the length, but its not cut at the correct spot or its not slow motion anymore.
How am I supposed to fix this?
If I export it all at 100% would it fix my problem? If that's the case.... how do I change ALL the clips to 100% and not interfere with the edit too much
So, I managed to disable all effects and get the speed up to 100% for all clips.
Once again, exported it as xml and imported it. It did help fix some clips but there are still several shots that do not match up to my edit
