Hello everyone. I wanted to add a video effect to a screen capture, but needed to export the pic then print and scan at a higher DPI and re-import to premiere pro 2 to add video effect and export again to use in photoshop CS2. I imported the pic back to premier at a higher DPI (the recommend range, something like 1096, I'm at work without access to my notes). When I re-import the pic in Premiere Pro 2 the pic shows up too big and/or as a black frame. I've tried 24 bit, 32 bit, different DPI. The only thing that works is a smaller DPI that isn't suitable for blowing up for poster use. I may be doing this the hard way, but not sure. I want to use the extract video effect, but not found in CS2. Premiere Pro 2 is exporting the screen grab at 96dpi, which is too low for a pic I want to put on a poster. Anyone have any ideas, advice? Am I going about this the wrong/hard way? Thank you in advance!
