Can I capture 24pA footage on iMovie, then use CinemaTools to remove the pulldown so I end up with 23.98 (progressive) quicktimes that I can then cut with in FCP HD?
The reason I ask is that in addition to my G5 FCP HD computer, I have an older G3 powerbook. I want to multitask and use my G3 to capture, while I cut on FCP HD on my G5.
The G3 can't handle FCP 4 or higher. But it has iMovie 4 installed, and I could also install FCP 3 on it. Before I waste time testing this scheme, has anyone done it or knows if it will work? I've never used iMovie before.
Just to clarify I'd be doing this:
24pA captured in iMovie @ 29.97fps, then brought into CinemaTools and converted to 23.98progressive fps.
I have in the past, converted 24pN (interlaced) 29.97 footage to (progressive) 23.98 in Cinematools and it looked fine... infact it looked exactly like 24pA footage, which makes me wonder what the point is of shooting 24pA when you have that flexiblity with 24pN to go either way.
