I'm getting fed up with my Letus35 Extreme! Help!
CelfistJett
Alright, so recently my Letus Extreme started to frustrate me. Mainly because when you move the camera back and forth, the "Box" of the screen when you zoom out all the way kind of wobbles back and forth, and not with the camera. It does it whatever way it pleases. Something must be loose or something, and I tried to figure it out by opening that sucker but I couldn't. Now for the second issue, vertically it won't center up anymore. It is too low, and I can't figure out how to vertically line it up.
Help is much appreciated! Thanks! :crybaby:
If there is any help, I use it with a DVX100B, and an AF Lens.
OIS = image stabilization. I believe it's behind the lcd, where the audio selections are.
OIS! Yes that's one problem solved, thanks! Now for the vertical alignment issue.. Any suggestions for that? Right now the image appears to be too low, but if I raise it up manually it can align, but it won't stay that way. The rails can't even keep it raised up the proper way.
