ikan vk7i DIY LCD panel repair info
Chiskon
Unfortunately this happened during transit to a shoot (broken LCD Panel)
I contacted ikan for a quote on repairs and it was $250 plus shipping.
Instead, I opened it up myself and found that the panel is a HannStar HSD070PWW1
That panel is only $35 after S/H and Tax with Buy it Now on Ebay. It took 11 days to arrive to California.
There were 10 screws on the back frame, 6 more screws holding the screen in place with a bracket (2 plastic and 4 metal), and only 2 connections to disconnect.
One was for the power switch and the other to the Panel. Aside from some mounting tape I put between the new panel and the 4 metal brackets, you just need the panel.
So if anyone else out there has the Vk7i that needs a LCD panel replacement, I hope this saves you some time.
Cheers,
Matt
Thank you for sharing this. So was it the outside screen that was cracked? This is what happened to mine and I'm wondering if your solution will fix my problem.
