IDVD And FCP
dvx100buser
hey, allright im running into a problem of motion blur on my dvds when a object moves its blurry strobing.....Im exporting from FCP full quality .mov quicktime movie no compression, cause i want full quality for dvd. Im trying to burn the file onto dvd using idvd im trying to get full quality and i dont know what im doing wrong thats causing motion blur can anyone help me thanks
Sounds like iDVD is doing your compression to MPEG-2 for you, correct? Probably not the best way to achieve quality DVDs.
Have you tried Compressor? Do you only have FCE?
Jason
im exporting to full quality mov file quicktime file no compression at all. also i tried a few setting on idvd and non of them are working for me, can anyone tell me what i should set what to. thanks
and also i have final cut pro not express final cut pro 5.0.4 is exact one i have....any ideas thanks i need dvds to be full quality dvds
thanks
Exporting full quality is a good idea. However, full quality (what ever that means in terms of codec, data rate and resolution) will not play in a dvd player without encoding first to MPEG-2 for dvd playback. In most cases, full quality video won't even fit on a data DVD without some kind of compression (DV, for instance, is 13GB per hour and a single layer DVD can only hold 4.7GB).
Since you are using final cut pro, I suggest you use Compressor to compress your file using the DVD best quality 90 minute settings (or 120min / 150min if your content is longer). For audio, use the dolby option if space is of a premium or the Aiff option if quality is more important than file size. Also, try turning ON frame controls and adding a little bit of detail, say +6.
Than import your .m2v and .aiff file into DVD Studio Pro, and use it to mux them together and then format/burn the DVD.
iDVD is not a professional program and will not offer professional controls. Compressor and DVDSP give many more options for tweaking a file and burning DVDs exactly how you want.
Jason
