A few thoughts:
If I want to use a slider, it is because it is easy and quick and own a 36" Kessler which nets me about 28-30 inches of travel. I have found that to be enough unless I have a particular need. That is the beauty of a slider; quick and easy. As soon as you add length, it becomes more problematic. I shoot with a good quality handycam and a smallish fluid head on the carriage adding up to about 8lbs of load. Unless I use my Kessler K-Pod and Hercules head, I use a tripod on one end and a light stand on the other. On a lighter tripod, I am just not happy with a single point mount. Kessler does make some nice larger slider options for both length, weight carrying ability, and motion control.
Although this solution is a bit out of fashion, I have the flexible track and track wheels for my K-Pod and it really does work well on flat surfaces and gives so many options for tailored camera movement almost like a huge slider with curved track. The K-Pod is a heavy proposition, but I like that as it makes things a lot smoother. Mass can be a good thing.
When folks discuss speed-rail, that is actually just a system of fittings to capture standard pipe sizes. Holeander is the most well known brand and can be purchased at most industrial supply house like Grainger. Any video company marketing thier own is just buying the fittings and re-branding them at a markup.
Pipe is sized from the inside diameter and the most common pipe sizes to use are:
1" with an OD of 1.375"
1.25" with and OD of 1.625"
1.5" with an OD of 1.9"
2.0" with an OD of 2.38
1.25" is the most common in industry rail work and is pretty typical for video use, as is the use of aluminum over steel.
Pipe can be purchased in different thicknesses denoted by "schedule". Sch40 being "standard" and both lighter sch20 and and heavy sch80 being available. To achieve the different schedules, the inside diameter varies somewhat, so a 1" sch80 pipe will have an inside diameter somewhat less than 1" sch40. The outside diameter remains the same for a given pipe size.
Tubing be contrast, is measured on the outside diameter. For example 1" tubing is 1" in diameter. So you always need to make the distinction between tube and pipe and how they are measured.
I have some lengths of 1.25" sch40 aluminum pipe for rail and it is ideal IMHO. I'd rather add support than hump the extra heavy sch80 pipe around, and sch80 aluminum pipe is worth a pretty premium to buy. When linking pipe together for a longer run, I have some solid aluminum round stock that is turned down to fit the inside diameter of the pipe. These are about 2ft long and have holes for bolts and is really solid when assembled. If you are intending to use these interior sleeves, make sure you purchase seamless pipe. Seamed pipe has a nasty little weld bead on the interior which will interfere with your sleeves.
Hey, I owned a machine shop in a former life.
G
G
