I think i messed up
You can control the amount of light on the subject with distance. You can also use a dimmer. You may also be able to substitute a different bulb with lower wattage. 100 watts will burn through a battery pretty fast.
thanks for your responce, but do i have to get a dimmer, or does this light have one? also, how fast are we talking here, if i use those 5 hr batteries? "You can control the amount of light on the subject with distance." you mean like move away and closer right?
I bought the same light kit at b&h for 75.00 less and it works ok. Not super great but the other people I shoot with have anton bauer and frezzies. Here is a link to b&h
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=208038&is=REG
The higher end lights seem to produce a whiter light but when you white balance with this light it does work. I shoot alot of weddings with this. The light is not a spot but works to about 8-10 feet.
like I said it works. It has saved a few shots and I always carry it with me to shoots even if I don't use it. My next on camera light will be a higher end one. I have found b&h to overall have pretty good prices and has a very good rep. I have heard bad things about broadway but have not ordered from them myself. Hope everything works out good for you and the best of luck with your shoots.
sean
mobiledeli said:
also, how fast are we talking here, if i use those 5 hr batteries? QUOTE]
What five-hour batteries? The light you're pointing to looks like it has some sort of belt-pack battery. Most of these on-camera lights will use a battery belt and either a cigarette-lighter or XLR plug for the power connection. A 100-watt battery will burn through a 10-pound battery belt in somewhere around 2 hours.
arent those 5000 mah (sp) around five hours? Also, I dont know it the one on broadway has that battery pack... I hope so.
EDIT: Thanks barry! I found that it does have a battery pack and I feel a lot better about buying it now.
