I have a problem with long ProRes 422 files recorded on an AJA Ki Pro. The critical file I need is 141 GB. A couple files in the 2 GB range import and play fine in Premiere CS5. But trying to import even a 14 GB file will not work. I instead get the error message "Unsupported format or damaged file." The larger files will not even open in the current QuickTime Player, telling me "error 2048: Couldn't open the file xxxxx.mov because it is not a file that QuickTime understands." Again, the smaller files play fine. Have any of you seen and solved this? There can't really be a size limitation can there?
I tried to download the ProRes WIndows codec from Apple's site and found that I already have a newer version installed (how does THAT happen??).
Of course this is a rush edit job too. Thanks much in advance for any advice you might have.
