I Need Help
THEMASTERMIND
I was told that this site would help me answer questions I have, so here I go.
I have a question about Autodesk 3ds Max.
For some reason, I have a blue box with crosshairs as my pointer while in a viewport.
Also, because of this I assume, I am no longer allowed to move, rotate, or resize objects.
Please help me, thanks.
I've not heard of the pointer with a blue box before. By chance do you mean the axis manipulator? If that has a blue box it means you are in "effect pivot only" mode. To correct go to the heirarchy panel and turn off this option (top button on the panel).
I believe that is the Transform gizmo. It allows you to move the object along the axis highlighted in Yello when moving the cursor over it.
