I Need a Longer Locking 3.5mm to XLR Female Cable
wisted
Why aren't there more of these available? Anyone with a mid to high-end wireless audio system should incorporate a cable like this into their arsenal...
http://www.bhphotovideo.com/c/produ..._1_5BX_EC_1_5BX_3_pole_Locking_Mini_Plug.html
...yet I cannot find them over 4.5 feet long! Has anyone else found one around 10' long or greater?
These are handy because wireless systems come with a threaded input jack to prevent accidental pull-outs and damage to the unit (pictured).
I own the UWP-V1, which is a godsend to quality audio, but it only comes with a six inch cable like this to support the included lavalier. If you're wanting to mount to a pole and use a shotgun, a longer cable would obviously be needed.
Anyone using 10' or greater length locking 3.5mm to XLR Female cables?
You can either add cable to extend it, or just buy a longer cable and re solder the ends on, should take all of about ten minutes. There might even be some tutorials on youtube.
Yeah. My first thought was to just throw a regular XLR cable on to extend it. If you don't want to do that, most audio shops that sell production gear and do service can make you a custom cable to whatever length you want.
...I cannot find them over 4.5 feet long! Has anyone else found one around 10' long or greater?
Actually using a wireless hop to the camera from a boom-mounted 'gun really doesn't require a super-long XLR to mini. You forget you must provide headphone monitoring to your boom operator - he can't aim the mic properly unless he can hear in real time the quality of the signal. The cable from the mic down the boom can be a conventional XLR cable. The operator wears both a headphone amp/preamp/phantom supply and the wireless transmitter side-by-side on his belt. The conventional XLR-XLR cable from the mic plugs into the preamp/headphone amp in order to tap off for monitoring. The preamp output then goes to the wireless transmitter at line level, only requiring a 6 inch or so XLR-Mini cable to bridge the gap between the two units.
I'd not want to buy a long one. Moulded cables are rarely tough cables, so using an XLR-XLR is so much more reliable.
I agree with paulears. You have an ADAPTER that looks like a cable. It was not intended to be the complete cable solution for all different configurations.
It seems to me that if you need longer, you have three options:
1) Simply use an XLR extension cable. That is actually the intended use-case.
2) You could DIY a cable of the desired length with those connectors. Not rocket surgery, but soldering to those little 3.5mm connectors isn't trivial, either.
3) You can have a cable made by a custom house. For example a 10 ft cable of your specifications costs $17.50 from www.redco.com
Yes and no. If you are clipping the transmitter on your belt and hand-holding a stick mic, the threaded ring keeps the twinky 3.5mm jack from pulling out.
OTOH, if you are running a longer cable over to some other equipment, and ESPECIALLY if the cable is across a walking path, I would rather have a connector that pulls out if the cable is tugged vs yanking the transmitter down and flogging it across the floor. And the typicall transmitter belt pack (or butt plug, for that matter) is small and light enough that I would probably gaff it down to something sturdy when used in a fixed location.
