jchenier said:Your problem might be the camera....Just my two-cents. [/url]
Hi Justin,jchenier said:Premiere Pro, either 1.0 or 1.5, capture digital video the same way. It's when you import into a timeline that Premiere Pro 1.5 treats it differently and removes the 24p pulldown. I used Premiere 6.5 for a long time, and when I started using PP1.5 I was surprised to find that all the capturing I'd done in 6.5 was recognized as 24p footage. Then I realized that it isn't in the capturing of the footage.
I hope that helps. The only way you can actually edit 24p footage as 24p footage is in Premiere Pro 1.5, and at that it's best if it's 24pA footage (advanced pulldown) since premiere has problems with the normal 24p footage.
The short answer to your question: upgrade to PP1.5
Justin
www.beyondtimemedia.com
Justin
