I deleted Audio Render files, now they won't re-render
awelgraven
I deleted some audio render files, in hopes of saving some space, thinking that since the original audio files were still there, if I ever needed the project again, I could simply re-render the audio.
However, when I open the project, Final Cut warns me of the missing audio renders. I check forget files (because they don't exist anymore)
Obviously, much of the audio in the project is unrendered, and thus, unplayable, but when I try and render the sequence, Final Cut pro errors out and says "File Not Found."
Is there any fix for this? Thanks for any help.
-alex
At first glance it sounds like you deleted more than just render files. You may check and see if the original files that it is making a reference to is still there. It may not be a bad idea to reconnect your media.
That's the strange thing. The original files are still there. I don't ever delete them. And the video files it will re-render. But not the audio. It's the strangest thing.
It could be that your rendering menu isn't set up right.
First, try doing an audio mixdown with CMD-opt-R. That should work.
Either way, go to the sequence menu, and under Render All and Render Sequence make sure "For Playback is checked" under audio.
Nope, same error message. I double checked to see if the original file was still there and it was. I can rebuild it...but i have other projects that have this same problem, and i really don't want to rebuild my entire soundtrack.
thanks for trying though
-alex
