Hyson Mattebox Review
Tim Naylor
Before people start ripping on me for not singing its praises, please understand, I wanted this to be the Holy Grail of indy matteboxes - you know perform like a pro for a paupers price. But so far I found in the mattebox world you still get what you pay for.
So here it goes:
Finally got my hands on a Hyson X Mattebox. The three stage, swing way, etc.
Pros:
- It folds up nice and tight
- looks impressive from a distance
- Adjustable x/y axis makes centering on lens
Cons:
- It's bulky as all hell. Clumsily designed. Nobs and screws loose fitting and cheap materials.
- Poor build. Very "homemade" in every respect. Lots of flex and jiggle. Would not stand up to car mount work.
- Large gaps between eyebrows and box which would be susceptible to glare.
- Trays are not dual (4 x 4 and 4 x 4.56, just 4 x 4.56)
- None of the mechanics (trays, swing way, 15mm mount, etc) are smooth to operate.
- Mechanics on swing not well machined or designed. Seems like a weak point for bending or alignment issues.
- Donut continually falls out
- Donut holder attaches in a somewhat dicey way
- Way too heavy. Stiff and rigid weight is one thing. But flimsy weight in this case is downright scary.
- In short, feels cheap.
I wouldn't use this in any paying or client based situation. Definitely not well suited for hand - held or vehicle work - too flimsy.
I was really hoping for something that performed as well as the pics - the holy grail of matteboxes, pro quality for indy prices. There's been so much hype about how well designed Hyson MB is. After using it, I feel this has been generated by folks who never had the chance to work with a quality MB and perhaps compared it too Cinecity, Formatt and the like.
If you're expecting Arri, Chrosziel, Petroff or Vocas like performance from the Hyson for half the price, keep looking. I'd rate if just a few ticks above Cinecity. Where Cinecity falls slightly short of Hyson in build quality, it ranks better in terms of simplicity. One poster claimed it was better built than a Petroff, that you need to take a hammer to dent it. Perhaps, as it's heavy but in terms of build and performance, Petroff is in a different league all together. For 200 dollars more you can get a simple Chrosziel two stage Sunshade for 15mm that will blow the doors off this in terms of usability and durability.
Hyson needs to simplify and design something sturdy for cheap. I feel it's trying to perform too many tasks and doing none of them well (3-4 stages, all rotating, four way eyebrows with adjustable leafs, swing way, etc. ) To have all these items and not machine well or use good materials, the rigidity and robustness decreases with each added feature. It's heavy and rickety. I think if they forwent the four way leafs in favor of hard mattes, they'd have something that's lighter, stiffer and with fewer moving parts. Also, if you can't do a swing way well, lose it. I find a light weight Chrosziel easier and faster to remove than swinging the Hyson clear.
That's my review. Wasn't out to piss on anyone's parade. Just called it how I saw it. I really wanted this to be a performer.
Tim Naylor - DP
Just my objective review
__________________
Cinetim
We just got our Hyson Matte Box also and the only issue I had was the weight. Not for the run and gun shots. Everything esle worked fine just what a matte box should do.
The RRMB is also on order and should be here hopefully this year. I hope hyson makes a lighter weight design with all the new revisions he is making.
All in all it works for us and we kinda urged hyson to just copy some designs
off Chrosziel and Arri just like what RR did instead of creating a new animal.
Lisa hayse
Your review is logical and it is typical when a company has a good designer but they don't understand manufacturing.
A company can design something in AutoCAD that is clean, simple and elegant. Then, they begin shopping it with manufacturing facilities. Many will talk them into small changes "that don't really matter." Before you know it, the designer's work is no longer recognizable.
And, if the manufacturer cuts corners on materials, cuts corners on manufacturing techniques (there are many ways to do the same task, but usually only one way to do it right) and doesn't have a QC process...you end up with a piece of junk.
Based on your review it sounds like the biggest step forward for this company would be firing their manufacturing company and finding a firm that understands craftsmanship and quality control.
I think the main issue with many of these manufacturers is premature release and inadequate beta testing. Sometimes things are designed and marketed by people who've never used them on set for any extensive amount of time. And if you're not a cameraman, then you must send out samples to camera folks for testing.
I truly believe the mattebox market is ripe for something simple but well made designs with off shore (re: Asian) manufacturing at a reasonable price. Nothing cheap is coming out of Germany any time soon.
I think Hyson aren't con artists like some manufacturers and honestly want to make a superb product. We're beginning to see the fruits of the low cost adaptor makers taking beta testing more seriously with their updates. Compared to two years ago, all three adaptor makers have engaged in the most entertaining arms race. Or you go the redrock route and delay release until you get it right. I hope Hyson takes an new approach and designs something truly simple, durable and precise. Maybe I'm naive, but I believe it can be done for less than the status quo.
If you can confidently put it on a car mount on a dirt road with no extra bracing, your heading in the right direction. If I don't have to put black paper tape on the gaps or anywhere else, you're doing well. If the trays slide in / out easily with no hassle-bravo. If it tightens with just "finger tight" force, the knobs are doing the trick. Sometimes something as simple as knobs and tightening, some people can never get right (anyone with a Letus rod attachment adaptor can attest to this). OR trays that get stuck (Cinecity owners shout out).
Overall, I love the design ambitions of the Hyson - just not the execution.
TIm Naylor - Dp
Voc
Hi Lisa,
To clarify, our microMattebox is an original design. As we always do, we set out to match a feature set. Anyone who has seen an Arri, Chrosziel, etc. next to the microMattebox knows they're very different.
Cheers!
I think when you design something like this to perform a certin task, it really designs itself. Anyone designing a mattebox to a certain spec is going to come up with very similar designs. The only variations would be different shapes and colours, and everyone knows it has to be black anyway...
