HVX200 is great, but I still need more sensitivity!
That's odd. Seemed to work great for me! I just looked at my post--the gimbal is slightly more than half-way above the center of the post (I have a few extra doo-dads on my DVX: a BEC wireless bracket, a Lectrosonics receiver, and a AT835b shotgum mic). The DVX with the ProPak14 felt "just right" to me! That's great to hear that the max load number is conservative. Did you have to pull the EVF and/or lens shade off of the Varicam? Wow, and Hytron 120s are HEAVY! I thought I would have to completely strip a 2/3" camera to mount it on the Flyer!
Well, the Hytron is mounted to the Steadicam, not the camera. The camera is powered through the 12V cable that comes with the flyer (the same battery that powers the Steadicam monitor powers the camera as well). It's possible that I even had two Hytron 120s down there to balance with the Varicam better, but I remember that being problematic because the little screw that holds the battery plate onto the base of the post unscrews in the direction of the weight (a design flaw) and two Hytron 120s down there are just too heavy for that screw to hold that baseplate up. I'm not sure if we had the EVF on the Varicam, but it was definitely "stripped." Just the body and the lens, and possibly the EVF. Of course this means that you have to be shooting wide and as stopped down as you can, because pulling focus on one of those shots is essentially impossible. The flyer wasn't made for the Varicam to begin with, but it was nice to know that the possibility was there, in limited uses. It was also just kinda fun to be flying a $100,000 setup. :-D
A DVX with add-ons would probably put the gimbal just above center on the post, so that sounds right. I like to have it about an inch from the top of the post, however, which is why adding weight to the top really helps. There's nothing "wrong" with flying it in either position (as long as it's balanced), but you'll notice that when tilting the post or doing low angle shots, it's much more likely to hit against the lower part of the arm. Obviously, the more range you have the better, which is why I prefer the gimbal to be higher. When we flew the Varicam, the gimbal had to be raised literally all the way to the top, the tension on the arm relieved completely, and tons of weight added to the battery section (by way of the Hytron 120s). Again, obviously this isn't what the flyer was aimed at, but it's cool that it's possible. :)
