HVX200 and shutter speeds
sodotoguwangus
When shooting in the 24p modes on the HVX, which shutter speed should I use for "standard" normal-style everyday shots . . . should I use auto-shutter, 50, or 48? (I believe the default auto shutter is set at 50).
I've heard that when using 24p modes, a shutter of 48 best emulates the look of film. However, I've also heard that the difference between 48 and 50 are Negligible.
"shutter off" will give you the default setting, which on a US DVX 24p would be 1/50th.
Just to point out for those coming from a bigger broadcast camera perspective, on the big cameras "shutter off" means that there's no shutter used at all, that the exposure is continuous. That's not what it means in a DVX/HVX. In the DVX and HVX, "shutter off" can better be thought of as "custom shutter off"; it means that instead of using a different or customized shutter speed, it will instead be using the default.
Huh? Then how do you turn the shutter off?
Meaning, how do you get 100% exposure? You'd choose 1/24 for 24p, or 1/30 for 30p, or 1/60 for 60p, or 350 degrees when in film cam/syncro scan mode.
Barry, I bet you wrote the book just to keep stupid questions like this from having to be addressed time after time after time!
I should get mine on Monday so you can start getting some sleep now.
Thanks.
