HVX-CS3 Aspect Ratio!
Lumiere
I know maybe it have been disscussed before but i couldn't sure about this.I use Premier cs3,so when i import my mxf nativelly is shows the footages on the bin like 960x720.I know its because it shows native frame size etc.When i want to export it,i manually set 1280x720 and square pixel setting which is results normal.Am i doing something wrong,or every cs3 and hvx user do like this.???
DVCPro HD in the 720p format uses a PAR or Pixel Aspect Ratio, Footage will always come in at 960x720 as the PAR is 1:1.333,
What is you final Export For?
Do you intend on storing uncompressed?
We Master our Finals using the Export to Panasonic P2 so we the best 1:1
with uneffected frames and a nice file size
You are doing it right. Every user that wants to encode to a square pixel codec needs to export to 1280x720 in order to maintain the aspect ratio of DVCPro HD at 720p.
Yes sometimes i export out uncompressed avi or QT,i also want to export p2 export for digibeta broadcast copy,but i have to bring it to another post company.Thats not problem but i wonder if avid can open cs3 P2 export nativelly and send it to final digibeta...:(
