HV20 audio setup
James Prods.
Hey guys,
I'm going to be purchasing a HV20, and am wondering what I need to get the audio setup for it.
I want to run a Rode NTG-2 (since I'll need to use batteries I believe).
I already have the boom, headphones, etc. planned out, I just need to know how to set it up for the HV20.
Thanks, sorry if its confusing.
You will probably want to add a BeachTek DXA-2s unit, and a good field mixer like the Sound Devices MixPre or 302.
The pre-amps in the Sound Devices mixer are a huge step-up from what is built-in to the Canon HV20.
Mics ---> Mixer ---> BeachTek ---> HV20
The BeachTek unit is set to LINE-IN levels, and you set the HV20's manual sound level to -12 dB using the 1 Khz test tone from the Sound Devices mixer.
:D
K so here's what I'm thinking, tell me if this sounds ok (no pun intended):
- Beachtek Unit
- Rode NTG-2 Mic (comes with shockmount)
- Rode Boompole (compatible with shockmount)
- And how's this for my XLR cable?
Thanks for the advice,
The Gitzo is a little out of my budget at the moment, but here's what I have so far:
- Beachtek Unit
- Rode NTG-1 Mic w/ Shockmount
- Rode Boompole
- Canare 25' XLR Cable
Sound good?
Total comes to about 600 $.
I'd say unless you are doing critical work which would be disastrous if you screw up, go without the beachtek at first if you're short for money. I don't use one, and the only problems I encounter are occasional buzzing when I'm plugged into an AC adapter. As long as you monitor with headphones to make sure that's not happening, you should be fine.
