Hi,
I'm used to SD editing and deinterlacing 50i footage in post to 25p. However, I now have the Canon HV20 which allows me to record in 25p. I therefore have to change my workflow but I'm a little unsure what settings to adopt in Sony Vegas.
1. For file properties, do I choose the HDV 1080-50i template or do I set a template up for 1080-25p by setting the field order to none. (I believe this only affects what the preview looks like in the edit so probably doesn't matter)
2. For conversion to SD DVD, I assume it is best to render as Mainconcept MPEG2 with DVD Arcitect PAL widescreen template but should I leave the field order as lower field first, to avoid deinterlacing, or set this to none. I assume leave as lower field first.
3. When rendering to wmv or any other computer based progressive output I assume Sony Vegas doesn't deinterlace the 25p edit (Would this require point 1 settings to be correct ?)
