Wow!
So far, it looks like Comer rules in price/performance/usability.
Exactly! Primo: I did not see a bit of difference, except a lack of WB. Secundo: both shots were quite garbage like due to dark shadows, which just shows the limitation of on-camera light.So it proves nothing except that lamp x looks worse if you color balance for lamp y. Else it was a waste of time watching it. Don't people who make these things know how to edit? I'm profoundly underwhelmed.
A bit of an assumption don't you think? I did not see any indication of color balancing to one light or the other---maybe I missed that. If that was actually the case, then I would agree the demo would not be worthwhile. I don't think it was though. The Comer is 4200K and it did look a tad blue in the video. I suspect a wb preset was used but that is just a guess. It should have been stated.So it proves nothing except that lamp x looks worse if you color balance for lamp y. Else it was a waste of time watching it. Don't people who make these things know how to edit? I'm profoundly underwhelmed.
In order to be even halfway valid, the camera would have been properly white-balanced for each light independently.
By editing, I mean that half the length of the video was watching the lights being turned up and then down again. This a waste of the viewer's time that should have been editied out. And more importantly, it diminishes whatever comparison value there is when looking at one image vs. the other. Cutting back and forth between the images is much more effective at displaying differences, just as switching back and forth instantaneously between speakers or whatever is a valid way to do A/B comparisons of sound.
And lastly, the heavy-handed editorial remarks puts the entire exercise in question about not only the validity and methodology, but also the bias of the "reporter". Bad reporting is worse than no reporting at all. Note that the video received similar criticism on the Vimeo site.
I have seen very few decent equipment reviews on YouTube, Vimeo, et.al. If someone has some to recommend, I'd be interested in hearing about them. And I'm talking about BOTH the production value of the review itself as well as the content (and in many cases the knowledge and experience of the "reviewer").
Really... ? You are going to blast me on something I did in 5 minutes?
Next time I plan on making a blockbuster out of a quick comparison, I'll let you know.
Untill then, keep your comments to yourself if they are going to be insulting - That is not what this forum is about.
For the record...
The 126 LED light is waaaaaaaaay off on it's color balance. And the included "gels" don't improve that at all. However, it's very bright and very cheap. I use it when I'm out in a very dark area and have no other light. I have found that the light with the CTO gel seems to balance to fluorescent.
I don't understand what you mean?
How can a light be way off on it's color balance? Do you mean the temperatur is not 5400K as stated by manufacturer or that the single LEDs differ in color?
Obviously the included 3200K gel of the 126 LED is garbage, but if this light is as bright as you desribe it, I don't see a problem getting 4 or 5 gels to adjust color temperatur to your needs in both directions, it'll cost just a few bucks; the 5 times more expensive comer just has 2 color temperatures to offer as well.
I think judging the quality of a LED video light by it's color temperature isn't fair, it's very subjective and a matter of personal needs.
