Kolor-Pikker
Starting over from a quick test I posted on the HPX250 forum, I've done a more thorough test of the kit lens that ships with the 3xx cameras, covering all focal lengths, both wide open and at f/2.8 with in-camera sharpening (detail) turned all the way down. This time I printed the ISO12233 target on a big 40x60cm glossy sheet, lit it under a pair of tungsten lights, and paid more attention to alignment. Focal length ranges from 77mm (100%) to 4.5mm (0%).
You can download a Photoshop file with aligned and stacked layers you can toggle through, or a zip with jpegs of the images, the .psd is uncompressed.
PDF (90mb): https://dl.dropbox.com/u/41183616/Fujinon 4.5-77mm zoom lens.psd
Jpegs (10mb): https://dl.dropbox.com/u/41183616/JPEG.zip
Yes, the lens really is that bad at 77mm, it's effect is clearly visible in actual footage.
Edit: Not sure how this ended up in General subforum.
