HPX 171/170 mount options
ROne
I'm getting there, but I can't seem to find out if I purchase a Ultimate/Elite whether I need anything other than rails to mount it to the camera.
I assume it's not like the HVX where things need to optimisation kits or step-up/down lens threads.
Do I just need the Ultimate/Elite rails (length?) and my flavour of lens mount?
This is what is in the bundle
"1 x LETUS 35 Elite Adapter Bundle includes Letus Elite Adapter, Rod Support System V2, Large Custom Storm Case - £2195"
Is there anything else I need to make it fit my HPX171 (72mm thread?)
thanks.
I believe the achromat is part of the adapter itself already and you can specify which step ring you want when you order.
So we don't need to order an optimisation kit for the HPX-170 and the adapter 72mm will fit the HPX-170 without any step ring ya?
Thanks guys, I'm still not 100% sure, as there appears to be no achromat option unless you buy the kit for the hvx which we know to be different.
There is a special HVX achromat for improved edge to edge sharpness on the HVX/EX1 camera, but if you order the Elite (as oppose to the Extreme) then this achromat is already included. The Extreme has just the regular achromat.
Thanks guys, so we are saying the HPX needs the achromat and is the same application as the HVX?
