HOWTO?? change multiple clips audio settings?
Joe Kocsis
I have about 40 clips that I want to mute channels 3 and 4 and bump channels 1 and 2 up 6 db.
Is there a way to do this in a single or few steps...
The only way I know is to open each clip and adjust it. Which is a bit of a pain..
Thanks.
Joe
you can just delete channels 3 and 4 then. just lock the other channels including the video then select 3 and 4 and delete them. thats if everything is in the timeline already.
and you can adjust one clip to +6db then copy that clips attributes then past the attributes into all the other clips by selecting them all. be sure not to reselect the original clip.
