I'm trying to set-up an overhead shooting rig for cooking videos. I was to position a 60x60cm mirror against the ceiling, angled down at 45 degrees so I can shoot into it from the ground to gain my 'top down' view. Ideally the tilt of the mirror would be adjustable by +/- 20 degrees. The mirror weighs 4.5kg.
In the past I've seen mirrors rigged with a couple of C-stands with boom arms with the frame of the mirror gripped with Cardellini clamps. This is a domestic house (my house in fact) and for various reasons I don't want to rig this up with floor stands. Ideally I want some sort of ceiling attachment that I can hook or otherwise attach the mirror (and any necessary supports) on to.
I can make attachments to the ceiling/drop-down box above the kitchen island. This is made of reasonably substantial MDF construction so happy it can take a bit of weight.
My key considerations:
I'd be really grateful for any suggestions/advice on how I might best set this up. I'm somewhat of a beginner - so any and all advice appreciated.
So far I've been thinking about:
I'm erring towards option one - with just a few hooks/chains. Using instead of just 'hooks' for security. It feels simple, easy to set-up alone, non-intrustive (given there is just the small ceiling attachments to clip/hook into. And any one of the hooks could fail and I'll still have three points holding the mirror up.
Hopefully the above is understandable. I've attached a couple of pictures of the area and mirror I'm working with.
Many thanks!
- I want to minimise the extent of/visibility of permanent ceiling attachments.
- Speed and ease of set-up (including ability to do this with a single person)
- Adjustability. To be honest, I expect once I've got my mirror/camera position set I'm unlikely to change it; but I can imagine that being able to adjust the mirror would be helpful.
- Attaching metal corner brackets to each of the mirror frame corners. This will reinforce the strength of the mirror and under one of the screws I could attach a chain to each corner. With two short chains (20mm or so) and a longer pair of chains (300mm or so) I'd achieve ~45 degrees hanging this from the ceiling. I could then install four non-intrusive white hooks to the ceiling to 'hang' the mirror. I could use different 'links' of the chain to adjust the angles.
- Attaching two baby pins (either long ones or with a 300mm extension), a right-angle bracket of some sort, and a pair of cardellini clamps to grip the mirror frame.
- Some sort of 'quick release' plate screwed to the ceiling, with matching attachment. Basically the same as the above, but a quick release rather than baby-pin set-up.
Many thanks!
