How to replace the lamp in a redhead
HBlack
Underage Member
Simple question. I can't find a manual or instructions anywhere online, so if someone could link me to one or explain it that'd be great. Pictures would really help as well. I don't want to damage anything, they're not my lights.
EDIT: The ianiro owner's manual only says "before removing", it never says specifically how to remove the lamp. Do you just pull it out?
Basically you just pull it out. The sockets itself is spring loaded and should give a little. Just grab the blown lamp from one side push into the contact a little and it should pop out. Do the same thing in reverse to put a new lamp in BUT remember to use a kim wipe or tissue when handling the new bulb - you don't want to get finger grease on a new bulb going in.
I'm not certain the bulb is blown, but the light doesn't work. It's my school's, so I'm not sure how the problem started. I'm going to try switching bulbs with another light to see if that's the issue. The lamp itself doesn't look damaged.
EDIT: Switched the bulbs, problem solved. Thanks for the help.
