How to Remove CS5 Contribute??? HELP
davdav
Hi,
I have installed the Adobe CS5 Master Collection on my PC to use Premiere Pro CS5 and now cannot remove the Adobe CS5 Contribute toolbars (and menu items in Excel) in my Microsoft office applications.
It's crazy!
I managed to remove it from Word, but it is still in Outlook and Excel. The toolbar appears every time I open Outlook or Excel, even if I remove or delete the tool bar through the customise toolbar options.
Also I cannot find Adobe Contribute in "add remove programs", and if I select Adobe Master Collection here, the only option is to uninstall the whole lot!
Note there is nothing in Google I can find for CS5. For CS4 and CS3 there are suggestions, but none of these work with CS5. Why does Adobe do this?!!
Any help would be appreciated. Thanks.
Add or Remove Program, select Adobe Master Collection. A menu will show up asking which program you want to uninstall. It won't make you uninstall the entire suite.
Excellent Huy Vu, it worked. Thanks!
One note for others is that you must be careful when uninstalling this way as it works completely the opposite to Microsoft Office uninstall, and the Adobe instructions are not sufficient. You must uncheck ALL check boxes and then only check the Contribute check box... then click UNINSTALL.
Thanks again Huy Vu
