How to record audio comunications in heli
Stelvium
Hallo friends,
wanted to ask you How to record a couple of seconds ofaudio comunications inside an helicopter with an external recorder?
Many thx
If what you want is just the communications why even start the beast up? If for some reason you need to be flying at the time you will need to patch into the com lines, maybe with something in the link above.
If you go that route make sure they know and are fine with it. You don't want to screw up the communications while you are in flight.
Also you may need to get permission from everyone who says anything. It really depends on the state but many require permission from everyone on a "tapped" line and that is essentially what you will be doing. Even ones that only require one persons permission, that one person needs to be a participant in the conversation, which you probably won't be.
