How to play timeline at half speed...
blando3
I just finished an edit that has lots of keyframes and motion and is quite complicated. The client has decided that maybe it should be slower. Is there a way to slow down the entire timeline before exporting to QT?
Thanks.
Nope. YOu can only do individual clips. SO...export a self contained QT file, re-import that, then slow that down...then export again.
You could nest your sequence, and then add a speed change to slow it down.
That might affect your quality, so if that's an issue what about this:
Can you copy the clip, paste it's keyframed attributes to a longer clip (make sure 'scale attribute times' is checked) and then copy the longer clip, then paste attributes back onto your original clip (might want to trim it to be a little longer?) and uncheck the scale attribute times? This should result in a slower animation.
Not sure how complex your stuff is, so that might not work.
