How to maximize workflow between Vegas and After Effects?
fixxxer76
I have vegas 10 and after effects 5 and I have footage shot on my t2i that I've converted to dnxhd. I want to use after effects to grade my shots. What is the best way to work between that and Vegas. I want to lock my cuts in vegas and then only edit those portions of clips. Then I want to put them back in vegas for the final output. Do I have to export each cut separately and grade separately? What if I have a sequence that will be all one graded color? What is the best way to do this. It just seems like it will take forever if I have like 100 cuts in a short flick. Thanks for the help.
If you install the 32bit version of Vegas 10....it still supports AAF export....you can then import it into AE and 'do your thing'...and bring it back.
(it still works that way with Vegas Pro 9)
Hope that helps...
Lets say I have a sequence with 3 different camera angles and multiple clips form each angle. I want to color grade the scene but need to tweak the color for the 3 camera angles. Can I render the entire sequence, (lets say its 1 minute with multiple 3-5 second cuts) import it to after effects, and then cut the clip at its camera changes and apply color grade to each of the 3 camera shots? or do i have to grade each individual 3 second clip.
