hopkins802
I have the Zhiyun Crane V1, A7sii that is powered using a dummy battery, and Canon 24mm 2.8 IS. I just started using the dummy battery on my gimbal, and because the wire is attached to the battery and sticks out of the battery door, I can only push the camera back so forward on the gimbal camera plate before it pushes against it. The camera setup is just barely, barely too back heavy because of this.
I tried putting the screw that comes with the crane to fasten the lens mount to the front of the gimbal, attached a big nut and washer as well, but it's still not front heavy enough. Can anyone thing of some sort of way I can weigh down the front more? Even with an ND on the front of the Canon 24mm, it's not front heavy enough.
Thanks!
Dan
Thanks!
Dan
