I'll be doing a project where I need to light it all up and I don't have that many experiences. The shoot will be later in the evening. (after sunset, dark outside).
I've attached 2 sample photos (location will look a bit different - photo below). 2 camera setup, one almost a locked position on the "doctor" and a another on the patient with a bit more CU shot.
It's going to be set up in a rectangular conference room (size about 30m x 10m) and the rooms lights are high ceiling tungsten (will check in the next few days) . Since I usually do simple one person interviews and events I only have a couple of Aputure 672S lights which probably don't have enough power.
I've also attached a picture of the location. It will be divided front 2/3 for audience and the last 1/3 (positioned left on the picture) for the procedure.
I can rent lights but have limited options. I'd like to avoid HMI lights because of the heat as this is a medical procedure.
This leaves me with next options
1) Kino flo lights
I was thinking 1x 2-bank or 4-bank system 4' for the Doctor and 1x 4-bank 2' for the patient CU. Should I also think about diffusing both lights using maybe 6"x6" silk frames?
2) LEDGO Bi-color Panel 900 - cheapest option
I can get my hands on a pair of this lights but I don't know if they are anymore powerfull than my 672s lights? I know them being bi-color makes only half of the LEDs work for tungsten and that's what is worrying me.
3) 3 light kit F&V K4000
As above, a bit worried about light output, will it be enough.
4) 2 x DMGLUMIERE Mini switch
2 lights kit with softboxes and "the dome" diffusor. Went to see them in person, they seemed powerful enough but the are the priciest to rent - about 8 times more than the LEDGO and about 2 times more than the KINO FLO.
Any other suggestions how I should approach this? Any suggestions?
1) Kino flo lights
