How to lav someone
Ferdi Willemse
Ok, this might sound pretty silly. However, I have to ask :)
I received my G2 kit two days ago (it's awesome) and I've been fooling around with it. The biggest question that went to my mind is how do you put a mic on someone? Where do you put the wire? How do you make sure the person wearing the mic has enough freedom to move?
Thanks!
This is from another site
http://www.equipmentemporium.com/Lavarticle.htm
Rigging lavaliers:
Outside the Clothing
In many situations, it is permissible for the microphone to be visible in the shot.
Needless to say, this simplifies the process of rigging the little devils quite a bit!
To begin with, you should be familiar with the proper technique of using a tie bar type mounting clip.
Secure the mic capsule (head) in the clip as one would expect. Then, loop the mic cable around in a "J" so that it circles upward and re-enters the tie clip.
The cable should pass freely through the closed end side of the clip where it hinges (the side farthest away from the jaws). With the tie bar in place on the clothing, continue the mic cable up and around so that it completes a circle behind the clothing.
Bring the cable back down (still behind the clothing) and secure it inside of the spring jaws of the clip.
The action of the metal clip will serve to eliminate conductive cable noise from being transmitted to the mic capsule. It will also strain relief the mic from any tugging or pulling on the cable.
The remainder of the lavalier's mic cable should be hidden behind talent's clothing.
Although it is acceptable for the microphone itself to be visible to the audience, there is never an excuse to see a sloppy cable!
The thin cable of the lavalier terminates at some sort of XLR connector/power supply.
This supply should be hidden either in a pants pocket, waistband, or at the ankle.
Never encourage talent to drag this XLR connector around; you risk great damage to the frail cable and electronic connections. Instead, always secure the connector end to talent, and simply plug a standard XLR mic cable into it.
At the end of a take, simply unplug the heavy mic cable from talent and they are free to roam the set without risk to your lavalier mic.
I have found that a heavy duty rubber band with a safety pin works well to secure the power supply inside of a waistband if there are no convenient pockets to use.
A heavy sock (or at least the ankle portion of one) works well at the ankle; as also does an ACE bandage or a salvaged ankle holster.
Even a strip of gaffers tape works well, but remember to line the ankle with cloth or toilet tissue first.
Velcro straps are fine on males, but will destroy fine hosiery and stockings.
Clip-on lavaliers are often attached to the center chest opening of a shirt/blouse or to the necktie. They can also be attached to the lapel of a sports jacket.
If attaching to a lapel, make sure that you attach to the side most likely for talent to turn towards. (Towards the interviewer, towards the projection screen, etc.)
Although the lavalier is visible to the camera, it does not have to be conspicuous.
Remember that in a wide shot, the lavalier is very tiny on screen. In a close-up, the lavalier will be framed out of the shot.
Just a little judicious camouflage will make the lavalier all but invisible. Cover the visible portions of the mic and clip with small strips of white camera tape. Color the tape with magic markers to match the color and pattern of wardrobe.
Hiding Lavaliers under Clothing:
Hiding a microphone under clothing requires much more attention to detail. Not only must the mic be hidden from view, but you must also contend with the problems of clothing noise.
Clothing noise comes in two varieties: Contact and Acoustic.
Contact clothing noise is caused by clothing physically rubbing against or striking the mic capsule or mic cable.
The best means to eliminate this type of noise is to immobilize the clothing around the mic. If the garments cannot move in relation to the mic, then they cannot rub or strike the mic!
Different sound mixers have different techniques for accomplishing this feat, but my preference is the use of sticky triangles.
But first, we have to eliminate cable noise.
Do this by forming one or two complete loops of the cable just below the mic capsule. The loops should be around one inch in diameter.
Tie the loops in place with a piece of thread or dental floss, or even a thin strip of camera tape sticky side out. The loop should be secured loose enough to open and close freely when the cable is tugged.
This becomes your strain relief. Secure the mic capsule within two small triangles of sticky tape.
I make these triangles from a 1" wide by 2" long piece of camera or gaffers tape, folded corner to corner several times like a flag, sticky side always out.
The mic is centered within the two triangles. Be careful not to tape over the grill or holes of the mic.
This sticky triangle can be placed just above a button of a shirt/blouse. The loop falls opposite of the button itself.
The next inch or so of cable should be taped onto the shirt so that it is between buttons.
Any tugging of the shirt or cable with be strain relieved by this strip of cable. The floating loop isolates the tugging from the mic capsule. The sticky triangles anchor the clothing on either side of the mic.
When wiring a female equipped with a bra, the sticky triangle can be re-angled so that it is flatside up, pointy end down, and can be placed inside of the bra, in the cleavage at the "cross your heart" point. The swell of the bosom acts as a shield against clothing noise, and results in excellent sounding mic placement.
The other type of clothing noise is that of Acoustic noise.
Acoustic noise is created not from clothing rubbing against or striking the mic, but instead from the clothing rubbing against itself.
Static Guard works very well to lubricate clothing, such as jackets rubbing over shirts.
Heavy starch conducts noise, so it is best dealt with by applying or spraying a little water around the mic placement area, as well as in any other areas that would not appear obvious to camera.
As a rule of thumb, cottons and woolens are the quietest clothing fibers.
Synthetics and silks are very noisy and should be avoided as much as the situation allows.
Lavaliers can also be hidden in other areas than just center chest.
Under the collar works well with sweaters and sweatshirts, or women's blouses. Going under the collar of a dress shirt on a male may create a problem if beard stubble is present on the neck.
Less conventional mic sites include under the brim of hats, or hidden in the hair at the forehead.
Small lavaliers can also be hidden on the frames of eyeglasses.
A very useful trick is to hollow out a plastic pen, and hide a lavalier inside. With but a very small incision in the back of a pocket, a pen mic can be planted in full visibility to the camera, with no clothing noise, and still remain completely "hidden".
Wind noise:
There are two types of wind noise: Contact and Acoustic. (Sound familiar?)
Contact wind noise is the one we most frequently associate with microphones.
That is the distortion caused when wind strikes the diaphragm of the mic itself.
The solution is to use a good windscreen. Which you will have to make yourself, because the flimsy little puffs of acoustic foam that come with most lavaliers are merely breath pop filters, not real windscreens!
The simplest tool for blocking wind is to salvage the foam booty that makes up the working end of a video head cleaning swab.
After you service your video heads, save these sticks! Believe me, the micro dust collected from a video head will not affect sound quality on a windscreen.
Pull the foam tips off of the wooden sticks, and then slice them open at the base to form a foam cap.
Slide the foam over your favorite lavalier, and instant windscreen. Since these screens are disposable, feel free to color them with markers for less visibility.
If rigging under clothing, feel free to sandwich them inside of your sticky triangles. So what if the tape destroys them!
A greater level of wind protection can be achieved by placing an oversize metal grill (such as from an ECM-55) over the foam.
Another trick is to wrap a layer of cheesecloth over the foam and the mic.
For visible mics, snip the fingertips off of a pair of wool knit children's winter gloves, and pull the wool "caps" over the cheesecloth. With a layer of wool, cheesecloth, and foam -- you're very well insulated from wind noise.
When hiding lavaliers inside heavy winter coats, a good technique is to bring the mic to the outside of the coat (to avoid excessive muffling) and to hide the mic under a patch of cloth or felt.
These patches are readily obtained as "sample" swatches from any fabric store.
The other type of wind noise is Acoustic.
That is the sound of the wind howling through the trees or between the buildings. It is a form of background noise, like traffic noise, and cannot be eliminated by the use of a windscreen.
Your best solution is to keep the mics close to talent. Rolling off the bass frequencies also helps a little, but wind howling is often all over the frequency spectrum.
Lavaliers as Plant Mics:
The best solution to clothing noise is to keep the lavalier off of the body entirely.
Lavaliers are too stupid to know whether or not they are attached on the body, or just near one.
It is a simple matter to hide lavaliers onto many handheld props, such as purses, clip boards, flash lights, cups, etc.
To rig a car, hide a lavalier on the inside of the sun visor. Any decent transparent lavalier will pickup driver, passenger, and probably backseat passenger.
The visor is padded to reduce echo, and well away from the bottom of the car with related engine & road noise.
Transparent lavaliers also work well as hidden mics in the set.
A mic in the centerpiece can give you a restaurant table. A mic in an executive pen set can pickup both sides of an across the desk encounter. A mic on the inside of a doorjamb can give you that short line from a passerby poking his head into the office.
Use your imagination!
A telephone booth is a snap to rig.
Someone reading directly off of a blackboard or bulletin board is perfect for a hidden lavalier.
The headboard of a bed for those "marital relations" shots.
Perspective:
A danger of using lavaliers is to forget to take perspective into account.
A proximity lavalier always sounds like a tight close-up, even when the camera is fifty feet away.
Transparent mics sound much more natural, but unlike boom mics, their perspective is fixed.
Booms move from farther to closer as the frame changes; lavaliers do not.
One quick fix to the perspective problem is to also deploy a shotgun mic directed at nothing in particular.
The "bleed mic" is used to capture footsteps, ambiance, and general sound effects from an angle that will not pick up dialogue (two mics capturing the same sound will create phasing problems, echo, and tinniness).
For long perspective, the bleed mic is mixed (say, 30%) with the dialogue from the lavalier. As the shot narrows to a close-up, the bleed mic is faded down, so that we are only left with the close-up sound of the lav.
Another trick to open up perspective when using lavaliers is to place them a little further down on the chest than normal.
This creates a noisier track with more ambiance and less forced emphasis of voice.
[FONT=&quot]Two actors playing opposite each other can be miked from each other's lavalier, again opening up the soundtrack to appear more natural. [/FONT]
