How to import footage using proxies but only convert 4K files? Premiere CC 2018
analogs
I am trying proxies on Premiere Pro CC 2018 and using the ingest method with the cineform 1024 x 540 settings. I have alot of files which is a mixture of 1080, 4K, mp4, mov, AVHCD, 24, 25, 50 fps, etc.
This is taking days and I am noticing that Media Encoder is converting every file I have imported in Premiere. Some files are being reduced in size whilst others are getting larger. I am running out of drive space.
Is there a way of only converting the 4K footage as that is majority where my PC struggles with?
Is there a way of setting parameters to which proxies are only created - ie. only if it is 4K or whether the file will slow down the performance of the computer?
Can I split proxies to different locations as my project hard drive is unable to accommodate all the proxie files for this one project I am working on.
Am I doing this all wrong and I need a better method? I have 900gb of footage on a storage drive. I am sending my proxies to a project drive 500gb so I can work on it but I am running out of space and I am only 3/5 ways of converting the footage into proxies. I also have a 500gb scratch SSD drive that I could use to share the proxies with but am I doing my approach wrong?
Thank you.
Turn off the Ingest feature. Once all media is imported, you can right click on selected clips and create the proxies that way.
