How to export with no pulldown?
STYLZ
Vegas 6. Export (render as options) 24p with 2:3 inserted or 2:3:3:2 inserted... Whatever. What if I want to export with no pulldown. I don't see that option specifically. Is it all right to use pure 24fps for web? Is pulldown needed? Also if anyone knows how to export in p.pro 1.5 with no pulldown that would be great too.
Thanks in advance
You can render as uncompressed with no pulldown (AVI).
If you render as WMV for the web, 23.976, it will have no pulldown.
You can do the same with QT.
That simple huh? So even though the template says 23.976 with 2:3:3:2 inserted...it's really not? Kew thanks Dave.
Under the DV options for AVI it says that, because you can't have DV without pulldown. But you CAN render an uncompressed AVI (option at the top of the list) which is straight 23.976p.
