HueyFilms Active member Aug 3, 2007 #1 How do I export a still in FCP that is native 720p but I want to export it so it doesnt look stretched... any help would be great. Thanks.
R RyanBellaCine Well-known member Aug 3, 2007 #2 have you tried just doing a shot? Apple+shift+4 to crop exactly what you want to capture. Last edited: Aug 3, 2007
M mark.burton Well-known member Aug 4, 2007 #3 Easiest way is to drop the frame you want to export into a standard HDTV 720p (1280x720) sequence with pixel aspect set to Square. When you drop the clip into the sequence, it won't match the settings, but it will result in a correct aspect still frame on export.
M mark.burton Well-known member Aug 4, 2007 #4 Alternatively you could use this very simple, free tool to resize the images after export. Resize 'Em All
