G
Guest
Guest
Im looking for any info explaining step by step the workflow for making 24P DVD's from footage that was shot in 24pa mode using Premiere, Premiere Pro or other PC based software. (Note:I posted this question in the Final Cut Pro section of this site as well)
After alot of research the way I understand it as of now is I basically need to first remove the 2:3:3:2 making it a true 24P file and put it on the time line. Next I edit the footage how I want it. Finally, as usual, I create a MPEG 2 file (60i because I guess you can't play a NTSC DVD with anything but a 60i file) of the footage to burn on the DVD but this time I add something called "flags" into the encoding which some how signal the DVD player to play the 60i MPEG 2 file progressively at 24 fps.
Correct me if Im wrong and if you have a link explaining what "flags" are, what they are doing and exactly how to add them.
Thank you ahead of time.
Brett Erskine
www.CinematographerReels.com
BELighting@mail.com
Brett Erskine
BELighting@mail.com
