How to capture images in 24p HDV mode without pull down process
zeka
How can I capture images that I shoot in HDV 24p mode to Adobe or Vegas without a pull down process. In Adobe I only saw project for HDV 30P or DV 24P.
So, In HDV(30P) project I've received a file with 6 more frame per second. Is there any way in Adobe Premiere or in Vegas to work in a project HDV with 24 frames per second. Is it necessary to setup anything in the camera for the uploud only 24 frames per second?
zk
Without pulldown flags, you can't remove the pulldown from HDV. The Canon X-series cameras include pulldown flags. The JVC HDXXX series records as straight 24p, so there's no pulldown at all.
If you're working with an HV20, you won't be able to remove the pulldown.
Actually the Canon X-series records straight 24P as well, directly to tape. So when shooting in 24F, there are only 24 frames per second recorded to tape. Which camera are you using?
