Zack Birlew
Hey guys, I know there have been guides all over the place to make a 35mm adapter and RedRockMicro has their own DIY guide I could get, but I don't know which one I should or want to do. I've got a GL1, yeah kind of old but some of the guides are designed specifically for the GL1/2.
Right now I could do the DVDLabs version with the spinning grounded dummy CD because I've taken the motor part out of an old CD player, I have yet to find a battery pack and solder the wires to it but it would have helped to include a how-to for that part since I'm a soldering newbie, and I also have quite a few dummy CD's I could go through on the grounding part, unfortunately I've been unable to find the CD-R pack by Maxwell the guide mentions that contains an already grounded dummy CD, and I have yet to get any grounding stuff, where would I be able to find this? Would a section of plexi glass work for the piece to ground the CD with versus getting a UV 4x4 filter? Though that particular guide is meant for 37mm cameras, I can adapt it to 58mm I'm sure, also Adorama has a ton of lens mounts that screw in versus having to use epoxy or something.
Then, I could always go with the Marla 35mm adapter idea, I can easily find a macro lens on B&H or Adorama in +1,+2,+3,+4, and +10 versions. The L-board construction base I can make on a visit to Home Depot I'm sure. But the camera part is the toughest part about it. So far I've been looking for Nikon F cameras and an F3 I found was like $500! I could just say "forget it" and go get a Letus35 which seems to be doing pretty good. Does anybody know of any other cameras with removeable viewfinders? Particularly cheap? This adapter seems the easiest since I don't have to make much.
Then the Home Depot 35 adapter is an option, I can probably get it to be smaller but that may be speaking too early.
Out of all of these, I'd prefer to be able to use my Formatt matte box on the end (I've already got a 58mm adapter ring). If not, then what would you guys suggest for light control? Cardboard matte box:grin: ? Also, is there some guide on how to make a brace plate or rod support for the added heft on the front of the camera? If not, then what rod support system would you suggest I get? The whole point of this is not to spend too much money on the adapter part and possibly spending a lot on a good lens instead. Speaking of the lens, what is the definitive lens that I should be looking for? What brand? Should I be looking for a 2.8 wide angle lens? A 2.8 zoom? 1.6 telephoto? I'd imagine that a 2.8 lens would be what I'm looking for since it's faster or am I mistaken? I don't know much about lenses
. With all of this I'm trying not to break Micro35 and G35 price levels, it is just a GL1 after all and I'm hoping to possibly make two adapters for a future 72mm+ threaded camera but that's just optional.
