ahalpert
Major Contributor
I've been rigging a 5lb payload (DJI RS3 mini gimbal + a7iv + 14GM) on a 13' light stand at maximum height to get a high-angle master shot of the wedding dance floor.
I've been using a single 15lb sandbag on it and keeping the unit at the corner of the dance floor where it's unlikely to be disturbed. But now i plan on moving it closer to the action once the central dance area has been determined.
My thought was that 30lb of weight might be sufficient for the casual bump into the light stand, or someone kicking the leg or swinging their arm into the column.
But is there a formula that we use for determining how much weight to throw down? Or is it just a guesstimate erring in the direction of too much rather than too little?
The worst case scenario is probably a heavy person falling backwards at full speed into the stand. What are your thoughts? I'd like to use the minimum weight necessary to prevent injuring a drunken guest.
