I'm no electrician, but I'm sure you need more than the minimum due to the higher start-up current needed to turn lights on.
Plus remember the numbers on the generators are maximum outputs for short start-up bursts and are not rated for constant use.
Your needs will vary depending on the type of light and generator. Are they 110v or 220v lights? What's the circuit on the generator?
This is as far as I'm sure of. Hopefully some one will come by and add to this or correct me if I'm wrong. Just be careful where you plug in that 2k!
Generators are generally rated as to what they can supply continuously. I would ignore the rating for intermittent loads beyond the continuous rating and just over estimate for the current draw. Keep power cables as short as possible and as high a gauge as you can use and you should be fine
Thanks a lot for your replies.
Chris, I am in the UK and our voltage is 230V the lights i'm referring to a 2K blonde and a 650W Arri light.
