When did the EBU say it wasn't good enough? They specifically endorsed 720p over 1080i (although they did say they'd prefer 1080p, but given the choices available to them they'd rather have 720p instead of interlaced).Resolution IS important. Question is, what resolution is good enough. I agree with many posters in that thread that 720p is good enough, even though EBU and BBC did not (still do not?) consider it to be HD.
Long ago they said that interlace sucks and they would prefer going progressive only, and that 720p is not quite HD, so they wanted 1080p. These were just recommendations, so no one cared much. I will dig up those statements when I have time. Yes, given the choice they would rather go 720p.When did the EBU say it wasn't good enough? They specifically endorsed 720p over 1080i (although they did say they'd prefer 1080p, but given the choices available to them they'd rather have 720p instead of interlaced).
BBC considers 720p to be standard def, but they allow using Varicams, go figure. They come up with unrealistic standards then they make concessions because they already have the equipment or they have got a good contract.And the BBC considers Varicam 720p to be HD, just no 720p from anything less than a Varicam.
The following formats are considered to be standard definition:
· All standard definition video formats
· HDV from all manufactures
· Cameras with image sensors under ½”
· Frame based (intra-frame) recording formats below 100Mbs
· Inter-frame based recording formats below 50Mbs (50Mbs Inter-frame compression is acceptable, however it must be kept in its native codec along the Post chain prior to delivery)
· Super16 film whether transferred to tape in high definition or not
· 35mm film transferred to or copied from standard definition tape formats
· Non linear editing codecs with bit rates below 160Mbs (anything over 160Mbs is accepted as lossless)*
· Live contributions links of less than 60Mbs (MPEG2)
· 720 line equipment with the exception of the Panasonic Varicam AJ-HDC27 range and the Panasonic AJ-HDX900 range**
*Other 720 line equipment may be acceptable but must be discussed prior to use
** A maximum of two low pass encodes (anything below 160Mbs) will be deemed acceptable on a HD Transmission master - one of these may be generated at the acquisition stage
Or, perhaps, because it's good enough?then they make concessions because they already have the equipment or they have got a good contract.
Resolution is just so easily measured and marketed. It's such a very definable and conveyable parameter that's easy for companies to manipulate and stick on the side of a box. So as far as consumer perception goes, unfortunately, Resolution is pretty important; as far as image aesthetic and perceived quality goes, the percentages in the article seem on the right track.
From the article below it sounds like the BBC is doing a fantastic job of mucking up the video on the way to the consumer.The BBC recommendations aren't about pixels. They're about what they feel holds up best on an end-to-end production chain.
http://news.bbc.co.uk/2/hi/technology/8415636.stm
Story trumps resolution any day. That's my answer to this threads question.
Sorry, I couldn't resist. Sometimes I think that everyone has forgotten about story and content.
