First some background. I have used several consumer Canon, Sony and Panasonic camcorders. Of these, all Canon and Sony HD camcorders had a built-in variable ND filter, the goal of which was to preserve aperture somewhere around F5.6 (HV20/HV30/HV40) or F4 (HF100, HC1). The filter is fully automatic, no direct control over it whatsoever.
Canon's ND filter had 1/4-stop gradation, up to 3 stops on the HV20/HV30/HV40 or up to 4 stops on the HF100. Sony's ND filter had 1/2-stop gradations, covering the range up to 3-1/2 stops.
Now I am reading about AUTO IRIS function on the Panasonic camcorders and I am not sure how similar it is to the Canon/Sony consumer setup. I am especially interested because the new HMC40 has a built-in ND filter which, presumably, can be turned on and off, but in ON mode it is "auto iris" only, no manual control over specific f-stop.
Could anyone in the know explain how Panasonic system is similar or different to Canon/Sony?
I came across this message on another site: "Turn on the DVX100 AUTO iris function and let the internal light meter process the light. You should see the f-stop numbers on the display change. From there, the display will either read “ND 1/8” or “ND 1/64”." Umm, it seems to have only two gradations, and these gradations are pretty crude, 3 stops and 6 stops.
With Canon/Sony system, the camcorder can keep relatively even brightness when lightning changes, because the ND steps are so small, especially with Canon. With the Panasonic system it seems that I would experience a serious jumps in brightness. Or, I would experience a serious change in DOF when the iris compensates for a huge 3-stop ND engaging/disengaging.
Another question. Barry wrote: "The A.Iris menu setting in the scene file has range from -4 to +4, and each tick accounts for about 1/3 of a stop of exposure compensation, so +2 would be about 2/3 of a stop brighter than +0 would be."
What exactly does this mean? Is it the same thing that is called "AE shift" on Sony camcorders or "Automatic Exposure compensation" on still cameras? This has no direct relation to the ND filter, has it?
An explanation and advice are appreciated. Thanks!
