how do I make titles look 24p-ee
im editing my short for this semester and will be doing credits AND subtitles. I added some titles to my last project and they looked very... video-y? not sure if they're just interlaced or what bu the deffinitly look different than the 24p footage.
Is there a way to make titles look more like 24p.
dont know, dont think so, shot 24p (F5) and imported the same way i always do, dont do anything special for a 24p timeline.
Any help appreciated :)
Simple yet may not be exactly what you are looking for:
Double click titles to open in viewer.
Open MOTION tab.
click OPACITY arrow.
Play around with different amounts of opacity settings, looking at how they look on your external tv. This should make it stand out less.
If you want your titles to have a 24p look, edit in a 24p timeline. If you have no idea what that means, please let us know what editing software you've got and maybe someone could help.
well i have an idea what it means although im not sure how to achieve it.
If i need to I'll try to since i shot in P instead of PA i didnt think id be editing in a 24p timeline.
Question:
If i did edit in a 24p timeline would that do what im looking for?
Is there a way to get what i want without going the 24p timeline route?
How hard is it to edit 24p if i shot F5 as opposed to F6?
If I understand your question correctly, then yes.
Here's what I would do. Create a different project for your titles in 24p.
Export them and import into your 29.97 (normal video) project.
You don't have to do anything special to make titles 24p besides making them in a 24p timeline.
I think you would have to load your clips individually into Cinema Tools and remove the duplicate
frames from the 2:3 pulldown.. It's no fun.. Try making your titles in a different timeline, export,
then import into your existing one and see if that works.
There is a sticky at the top of this forum about "Editing 24p in FCP" written by Noah Kadner.
Read it for the future. Pretty good info.
great idea about creating just the titles in 24p and importing them!
so far I've always shot F5 since i knew everything i made would be shown of an interlaced tv. I might have to rethink this on whatever big thing i do next.
Too White
Too White
If your titles are white, then you should use a little darker color then the whitest white, like a light grey. It will look white on a ntsc monitor, and white will look too bright and flickery. My tv also has some scratchy noise when I forget to tune down my titles. That may help also.
Joe
i'll add to the changing opacity on the titles and also try slowing down the titles a little. Is there a way to do that with speed? or do you just add a bit of blank (extra space) at the end of the titles to slow it down? or wait, guess you would just extended it a little longer. The opacity change always fixes things though.
Make sure your color text is not WHITE.
The RGB channel needs to be 190,190,190 for thick or basic text.
Anything else like thin/curvy text... needs to be darker or larger.
Also, decrease the transparency/opacity of absolute black to 90%
Make sure you add a light "blur" filter to that while you're at it.
SMPTE specifications for NTSC white in RGB values is 235, 235, 235. Anything beyond that is an illegal level, anything less is a creative decision until you hit 16, 16, 16...
Michael
Michael
Yes and no. The waveform in FCP has nothing to do with the outside world. In other words, its your output card that does. I do broadcast programs and must have an external waveform in order to get accurate readings as the waveform in FCP doesn't know what language the outside world is. Yes 235 is white in the real world for conversion purposes but once again it matters more on how its being output than that number in FCP. I'll give you an example. zero black (0,0,0) on a FCP system is zero on an FCP scope but since I am outputting to a decklink card with set-up added, 0 turns out as 7.5 in the real world. 16,16,16 in aFCP scope is 10 units of video and 16 units of video in the real world on a scope outside of FCP. 32,32,32 on a FCP scope is 18 on a FCP scope and 22 units of video in the real world. white (235,235,235) on FCP is 94 units of video on an FCP scope and 91 units on a real scope in the outside world. super white (255,255,255) on FCP is 100 units but 96 units of video in the real world. The point is that FCP doesn't know what the real world is and doesn't care. This is why if you want to know what levels are for your TV set you need an outside scope. And with a real scope you can comfortably set your title whites to 80 units which is the standard we use in broadcast when mixing it with film footage. To do that in broadcast we make a 255 white and simply reduce intensity to 80% or so.
I've gotten a pretty good facsimile of 24p using After Effects. You set the composition to 24p, and the render settings to use pulldown.
As far as the image, I usually add a slight drop-shadow, blurred, and set to zero offset. This makes a slight black halo around the text, and cuts it out of the background. Used subtly it makes the text look very film-like. And, if you want to get crazy, add a quarter- or half-pixel blur, maybe a touch of grain/noise, and maybe even some jitter motion to simulate gate weave.
But usually the drop-shadow is enough.
