Y yabyum Well-known member Jan 25, 2012 #1 I want the electricity to appear and dissipate on something... like a tissue paper being burned, it has little worm like glows moving through it... hope I'm describing this well.
C Cassius Veteran Jan 25, 2012 #2 After Effects has a lightning preset. You can keyframe the origin and direction of the strike to move it around. That's the easiest way.
Y yabyum Well-known member Jan 25, 2012 #3 ^ Thx! Update: Found this tute which will help, it's similar: http://vimeo.com/16525054 And this is a pretty clear example of what I want: http://www.youtube.com/watch?v=wsw9SNwbD64&t=1m12s Will report back if I figure it out. Gonna play around for a while in AE / work on a project
Justin Kuhn Veteran Jan 25, 2012 #4 Lightning filter on an adjustment layer, put masks on the layer and animate your masks according to the desired pattern of dissipation.
