B blando3 Well-known member Jun 4, 2008 #1 I just received a Flash Video file (FLV) and need to edit it in FCP. Is there a way to convert it to a Quicktime movie? Thanks, Andrew
Chris Santucci Veteran Jun 6, 2008 #3 I use iMovie. It's pretty easy. Just drag the clip in and export as whatever you need. .
Michael T Well-known member Jun 6, 2008 #4 There is also VLC and VisualHub and Mpeg streamclip and I believe you can use Quicktime Pro. Good Luck
Ferret Lady Well-known member Jun 8, 2008 #5 i use visual hub. you can convert to any type you want, it's fast, and simple to use.
